03-01-2018, 03:54 PM
A litte program that translate colors on resistors
can also us it in calculation like this 1/(1/resistor + 1/resistor)
/Lars
// Initialize procedures used in project (by khapster)
EVENTHANDLER();
PUTMENU();
GETMENU();
DRAW_RES();
DRAW_COLOR();
//Program created by by Lars F.
//Credits: salvomic, Cyrille de Brébisson, Akmon, Dale (DrD), Eddie W. Shore, Didier Lachiese, kharpster
mSEL;
eTYP;
kP;
m;
m1;
lookup;
// things to do
// remove black from menu on first color selection. Done
// remove grey and white selecting third color. Done
// add support for 4 color resistors?
EXPORT Resistor()
LOCAL mx,my,meny, active_menu, colors, count, res;
meny :={ {"Black","Brown","Red","Orange","Yellow","Next"}, {"Prev","Green","Blue","Purple","Grey","White"} };
lookup := {"Black","Brown","Red","Orange","Yellow","Green","Blue","Purple","Grey","White"};
colors := {"","",""};
count := 1;
active_menu := 1; //start menu
DRAW_RES(colors); // draw a sketch of a resistor
// at this time only resistors with 3 colors is supported, skipping tolerance
WHILE count <= 3 DO
PUTMENU(meny[active_menu], active_menu, count);
// Flush the mouse buffer
WHILE MOUSE(1) ≥ 0 DO END;
// Loop until we have a keyboard or mouse event
REPEAT
EVENTHANDLER();
UNTIL eTYP <> "";
CASE
// If the event type was a keyboard action then process it
IF eTYP == "K" THEN
// If the ESC key was pressed set the program to end
IF kP == 4 THEN
KILL;
// If the event type was mouse action then process it
IF eTYP == "M" THEN
// Convert mouse coordinates to decimal
mx := B→R(m1(1));
my := B→R(m1(2));
// Determine if mouse coordinates are inside of a valid menu item otherwise return a zero
GETMENU(mx,my,meny[active_menu]);
IF mSEL > 0 AND mSEL <= 6 THEN
CASE
// If menu item 1 and 6 need some special treatment
IF mSEL == 1 THEN
IF active_menu == 1 AND count > 1 THEN // skip if on first color selection (black)
colors(count) := meny(active_menu,mSEL);
count := count + 1;
ELSE // previous pressed.
//RECT_P(); // clear screen
active_menu := 1;
PUTMENU(meny[active_menu],active_menu,count);
IF mSEL == 6 THEN
IF active_menu == 2 THEN
count := count + 1;
ELSE // next pressed
active_menu := 2;
DEFAULT
count := count + 1;
END; //case
// draw the color if any color pressed
IF count > 1 THEN
DRAW_COLOR(count-1,colors(count-1));
END; //mSel
END; //eTyp
END; //case
END; //while colors
// we got 3 colors, now calculate the value
res := "";
FOR I FROM 1 TO SIZE(colors) do
IF I == 3 THEN
FOR J FROM 1 TO POS(lookup,colors(I)) - 1 DO
res := res + "0"
END
ELSE
res := res + STRING(POS(lookup,colors(I)) - 1);
END
// cleanup
LOCAL pre;
LOCAL value;
value := EXPR(res);
IF value >= 1000 THEN
IF value >= 1000000 THEN
value := value/1000000;
pre :="MΩ";
ELSE
value := value / 1000;
pre := "kΩ";
ELSE
pre :="Ω";
// print the value
TEXTOUT_P("Resistance= " + value + " " +pre,50,150);
WAIT(2);
RETURN EXPR(res);
EVENTHANDLER()
eTYP := "";
kP := GETKEY;
IF kP <> -1 THEN
eTYP := "K";
ELSE
m := MOUSE;
m1 := m(1);
IF SIZE(m1) > 0 THEN
eTYP := "M";
// Draw the menu using the list passed in
PUTMENU(mTXT, num, c)
CASE
IF c == 1 AND num == 1 THEN // selecting the frst color, no black
DRAWMENU("",mTXT(2),mTXT(3),mTXT(4),mTXT(5),mTXT(6));
IF c==3 AND num == 2 THEN // about to select third color, removing grey and white
DRAWMENU(mTXT(1),mTXT(2),mTXT(3),mTXT(4));
DEFAULT
DRAWMENU(mTXT(1),mTXT(2),mTXT(3),mTXT(4),mTXT(5),mTXT(6));
// Get the number of the menu item selected (1-6) by checking mouse position
// Menu items with empty/blank text will return a zero
GETMENU(mx,my,mTXT)
mSEL := 0;
IF my≥220 AND my≤239 THEN
CASE
IF mx≥0 AND mx≤51 AND mTXT(1)>"" THEN
mSEL := 1;
IF mx≥53 AND mx≤104 AND mTXT(2)>"" THEN
mSEL := 2;
IF mx≥106 AND mx≤157 AND mTXT(3)>"" THEN
mSEL := 3;
IF mx≥159 AND mx≤210AND mTXT(4)>"" THEN
mSEL := 4;
IF mx≥212 AND mx≤263 AND mTXT(5)>"" THEN
mSEL := 5;
IF mx≥265 AND mx≤319 AND mTXT(6)>"" THEN
mSEL := 6;
// draw a resistor....
DRAW_RES(color_list)
LOCAL mots, ring,colors;
mots := {110,108,120,110,120,110,200,110,200,108,210,108,210,132,200,132,200,130,120,130,120,132,110,132,110,108};
RECT_P();
FILLPOLY_P(mots,#FFE5CCh);
LINE_P(60,120,110,120,#00h);
LINE_P(210,120,260,120,#00h);
// draw the color
DRAW_COLOR(number,color)
LOCAL ring,colors;
ring := {{130,110,142,130},{154,110,166,130},{178,110,190,130}};
// black brown red orange yellow green blue purple grey white
colors := {#000000h,#994A00h,#FF0000h,#FF751Ah,#FFFF00h,#33CC33h,#3366FFh,#9933FFh,#808080h,#FFFFFFh};
RECT_P(ring(number,1),ring(number,2),ring(number,3),ring(number,4),colors(POS(lookup,color)));
/Lars
