02-28-2018, 08:44 PM
I have recently acquired a 39GS for very little money from China. Now I am wondering if anyone has managed to successfully run new RPL on a 39GS and if so, where can I download the firmware?
Cheers,
Harald
Cheers,
Harald
(02-28-2018 08:44 PM)Harald Wrote: [ -> ]I have recently acquired a 39GS for very little money from China. Now I am wondering if anyone has managed to successfully run new RPL on a 39GS and if so, where can I download the firmware?
Cheers,
Harald
(03-01-2018 08:40 AM)Harald Wrote: [ -> ]Thanks for the pointing me in the right direction!
Now I have a new problem. I downloaded the connectivity kit for the 39gs from the HP website. The newest version is for Win XP 32 bit. I have Win8 and apparently that is unhappy with the drivers. Any Ideas? Has anyone succesfully flashed from Win8?
Cheers,
Harald
Cheers,
Harald
(03-01-2018 11:39 AM)toml_12953 Wrote: [ -> ]Thanks for the link! Unfortunatelly I get the same helpfull message saying "installation failed" when trying to install those USB drivers.(03-01-2018 08:40 AM)Harald Wrote: [ -> ]Thanks for the pointing me in the right direction!
Cheers,
Harald
Maybe this will help you. If it runs on Win 10, it should work on Win 8:
Install HP 39gs CK on Windows 10
(03-01-2018 12:06 PM)Harald Wrote: [ -> ](03-01-2018 11:39 AM)toml_12953 Wrote: [ -> ]Maybe this will help you. If it runs on Win 10, it should work on Win 8:Thanks for the link! Unfortunatelly I get the same helpfull message saying "installation failed" when trying to install those USB drivers.
Cheers,
Harald
(03-01-2018 12:36 PM)toml_12953 Wrote: [ -> ](03-01-2018 12:06 PM)Harald Wrote: [ -> ]Thanks for the link! Unfortunatelly I get the same helpfull message saying "installation failed" when trying to install those USB drivers.
Cheers,
Harald
Did you disable the check for unsigned drivers? By default Win 8.x and 10 won't let you install drivers that aren't signed. You can defeat this, however:
Disable Signed Driver Enforcement
(03-01-2018 09:49 PM)Harald Wrote: [ -> ]Thanks to everyone for the hints! I now have a 39gs running newRPL!
"All" I have to do now is get my head round how it is operated.
Cheers,
Harald
Cheers,
Harald
(03-23-2019 06:08 AM)math7 Wrote: [ -> ]Thanks to Claudio for this tool, it is fabulous, recently I installed newRPL on my HP 39gs and I am getting used to its operation, but I do not know how to transfer files from the PC to the calculator. I suppose you can install applications and programs from the HP 50g in the HP 39gs because they are compatible at the RPL level, but how are they copied to the HP 39gs? The connectivity kit of the HP 39gs I managed to install in windows 10 but does not recognize the calculator with the newRPL already installed. I tried to use the newRPL virtual calculator from HP 39 but I do not know if it is useful to transfer the files to the physical calculator or how it is done. Could you give me a light in this regard? Thank you...
