02-27-2018, 04:23 AM
A bit of background.
I have found that Connectivity between HP Connectivity Kit and HP Prime Pro Android app can be flaky at time. Sometimes I found if I start the Connectivity Kit immediately on boot up and login it would work. I noticed if I was using a vpn (its a 2nd network adaptor in windows) the connection would not work.
This made me think is the hp connectivity app choking on systems that have more than 1 active network adaptor.
My laptop also has Vmware Workstation installed (this creates at least 2 extra network adaptors with private ip addresses assigned to them). So when I found the connectivity between android Prime and windows con kit was not working. I disabled the 2 vmware network adaptor in windows and restarted the kit and miraculously the HP Con Kit was available in Android.
It appears that the HP Connectivity Kit doesn't handle multiple active network adaptors on the same machine gracefully at times and when its not showing up I have to disable the 2 extra network adaptors temporally to get it running.
NB:
I HATE WINDOWS it is always finding ways to bite you in the bottom.
NB:
