(02-07-2018 09:26 AM)Gamo Wrote: [ -> ]The highest prime number that fill 10 digits calculator screen is 9,999,999,997
The next prime is 10,000,000,019 which is 11 digits that can't fill in the screen.
1000000001 R/S result 9 > 10,000,000,019
1000000001 R/S result 03 > 10,000,000,103
I assume the last line is supposed to read
1000000010 R/S result 3 > 10,000,000,103
Now, what do you want to get if you enter a 10-digit number like 1.000.000.001?
- The next prime with 11 digits?
That's 10.000.000.019, so the output is 9 ?
This means: determine the next prime after 10*x.
- The next prime with 12 digits?
That's 100.000.000.103, so the output is 03 ?
This means: determine the next prime after 100*x.
- The next prime with 13 digits?
That's 1.000.000.001.051, so the output is 051 ?
This means: determine the next prime after 1000*x.
Let's assume you mean the first case. "Determine the next prime" here simply means:
Check if the following numbers are prime:
10*x+1, 10*x+3, 10*x+7 and 10*x+9
So it boils down to an algorithm like this:
input x
found=false
p = 10*x+1
checkprime(p)
p = 10*x+3
checkprime(p)
p = 10*x+7
checkprime(p)
p = 10*x+9
checkprime(p)
if not found then print "No primes between " 10*x " and " 10*x+9
end
subroutine checkprime(p):
if isprime(p) then
print p
found=true
end
Now, how do you check if an 11-digit number is divisible by, say, 7 while all you got is a 10-digit calculator? I'd say this can be done. Think hard. ;-)
Dieter
