General Forum
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226
Announcements
Threads
- Found bugs in HP-15C LE (10 Replies)
- HP 97 print issue (4 Replies)
- Moding Card Reader for 5V Power (11 Replies)
- "Hewlett Packard" not on the front of HP12c Platinum (17 Replies)
- Tripartite Palindromic Partition of Integer (HP 50g) Challenge (127 Replies)
- HP41 Battery idea Lipo (9 Replies)
- Catalog of Contributed Programs? (7 Replies)
- HP-65: uneven feel of the keys (4 Replies)
- HP82143A Powering a 41 _Extend Your HP41_ (14 Replies)
- decode an internal sticker (not a serious topic) (2 Replies)
- HP 110 (not Portable Plus) Technical Manual (4 Replies)
- Did you know the 2nd bathch of Spice calculators are more accurate? (14 Replies)
- HP-65 neg mantissa (1 Reply)
- 1971's Smallest Battery-Powered Calculator: Dictaphone 1680 (4 Replies)
- HP50g True RS-232 Serial Cable Created by Allen & Eric ( Found :) (0 Replies)
- HP-48G local variables within subroutine (11 Replies)
- HP41CV with built-in Time Module (4 Replies)
- little math/programming problems April 2023 (13 Replies)
- Small challenge (39 Replies)
- Hp 50 ; ± What's behind that command/program? (1 Reply)
- ChatGPT for programming (36 Replies)
- [VA] SRC #012f - Then and Now: Angle (15 Replies)
- HP-41CV: Strange "Power Management" (11 Replies)
- HP15c CE: 8x8 equation system (21 Replies)
- [HP48] Kermit setup (9 Replies)
- Proper way to terminate a HPGCC C program after using hpg_set_mode_xxxx()? (4 Replies)
- New HP 15c CE speed tests (18 Replies)
- HP 12C Plus (4 Replies)
- HP41 FOCAL programming: characters on stack? (2 Replies)
- HP 110 "garbage" on screen (29 Replies)
