Re: Prime Emulator Connection Problem Message #2 Posted by Tim Wessman on 14 Dec 2013, 7:20 p.m., in response to message #1 by John Colvin
It does. There is a new menu called "Connect To" in your emulator. Your calcualtor will show up in there by name. You need to tell it where you are connecting to. Before, the connection could be grabbed by several different things and you'd never know where exactly the communication was going.
For example, did it go to the second emulator that was up, the connectivity kit, 3 usb connected calculators, or the 30 running on your wireless network... (granted the last ones are probably only a problem for me right now)
TW
Edited: 14 Dec 2013, 7:22 p.m.
