Re: Prime still frozen Message #2 Posted by Joe Horn on 8 Dec 2013, 7:10 a.m., in response to message #1 by Les Koller
When I turn my Prime on now after several failed attempts to upgrade the firmware, it now stays on the large X^2 + Y^2 = 1 screen. Anyone have this problem and successfully fix it?
Yes, in fact that just happened to me yesterday, after a firmware upgrade failed halfway through. The following fixed it:
(1) Hold down the Symb key while performing a paperclip reset. That should launch the "recovery mode".
(2) Navigate to the Connectivity Kit's installation folder. On my computer (Win 7, 32 bit) it's here:
C:\Program Files\Hewlett-Packard\HP Connectivity Kit
(3) Execute the "Updater.exe" program directly from that folder by double-clicking it. Your Prime will be re-flashed.
This assumes, of course, that you downloaded the latest firmware from HP.
Hope it works for you like it worked for me! If it doesn't, you might have to do the C+F+O+On procedure to "Format Disc C".
-Joe-
