Re: Updating Prime Message #4 Posted by Helge Gabert on 6 Dec 2013, 11:58 p.m., in response to message #1 by Les Koller
I had the same problem. Make sure you use a USB port, not a hub, open the CK, let windows find the "device", let the CK find the 5447 Prime firmware update and install it (in a subdirectory below the CK), reboot the computer, make sure the physical Prime gets recognized, only then update firmware.
Good luck. I managed to totally mess the boot loader, and needed to run the Prime recovery kit.
