HP Forum Archive 21
I can't update HP Prime
Message #1 Posted by JavierLopez on 5 Dec 2013, 5:25 a.m.
Hi. I do all the necessary step for update. I start HP connectivity kit, click "help" and then press "check for update". Later I click with the right button on my HP Prime and click Update firmware, but this is what happen: I try to solve the problem reinstalling hp connectivity kit, deleting HP Connectivity Kit folder in My Documents, reseting the calculator... but the problem persist. Can anyone help me? Thanks
(deleted post)
Message #2 Posted by deleted on 5 Dec 2013, 1:22 p.m.,
in response to message #1 by JavierLopez
This Message was deleted. This empty message preserves the threading when a post with followup(s) is deleted. If all followups have been removed, the original poster may delete this post again to make this placeholder disappear.
Re: I can't update HP Prime
Message #3 Posted by Tim Wessman on 5 Dec 2013, 2:20 p.m.,
in response to message #2 by deleted
I would not recommend following this procedure and would ask you not to be sharing and encouraging use of it. It has the possibility of breaking your unit since that tool can overwrite the boot loader.
TW
Message #4 Posted by Carlos CM (Mexico) on 5 Dec 2013, 3:13 p.m.,
in response to message #3 by Tim Wessman
Check this:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/forum.cgi?read=257593#257593
you should download the firmware, connectivity kit and emulator with the ultimate date... (25_11_2013)
ftp://ftp.hp.com/pub/calculators/Prime/
Good luck..!
Message #5 Posted by LHH on 5 Dec 2013, 7:55 p.m.,
in response to message #4 by Carlos CM (Mexico)
I'm also having no luck updating the physical calculator. It appears the CK and virtual calc are happy but when I try to connect the physical device and select "update" I see a message at the top of the Prime screen (something about ...V13 I believe) and the message box on the PC screen attempts to do the update (5-6 automatic retries) and then ends (fails) with error 104. At this point the physical Prime is no longer shown in the CK list and the Prime itself is unresponsive until it is reset via paperclip.
The files in the CK firmware directory seem correct although the .dat files are shown as type "TiePie WinSoft Data", TiePie being a data acquisition system (hardware and software) used on this machine. I think I approved the file association when I originally installed the TiePie system and I'm tempted to remove it temporarily to see if that makes a difference. I thought I would check here first though in case the problem lies elsewhere.
I tried to update twice last night so my memory of events is a little fuzzy. Getting a little nervous about this now.
Thanks for any suggestions!
Message #6 Posted by Joe Horn on 6 Dec 2013, 10:37 a.m.,
in response to message #5 by LHH
Be sure to connect directly to a USB port on your computer, not a USB hub. Apparently it makes a difference for some hubs.
Message #7 Posted by Tim Wessman on 6 Dec 2013, 11:24 a.m.,
1. Is that a virtual machine, or real unit? 2. File association should make no difference. 3. The updater has to use a direct write to the flash drive which counts as a low level process. Hence the admin rights requirement.
If it still is not working for you, I'd recommend calling the support line.
TW
Message #8 Posted by JavierLopez on 6 Dec 2013, 10:37 a.m.,
I saw that post, and that was the step I did. For that reason I create this post. I hope there are any solution thath don't break my hp prime.
