Re: [HP Prime] Plots containing complex numbers bug? Message #8 Posted by cyrille de Brébisson on 5 Dec 2013, 7:40 a.m., in response to message #1 by Chris Pem10
The main problem is that you are using mathematical functions (^ to a non integer, or NTHROOT) which happends NOT TO BE FUNCTIONS by the strict definition of the word function.
ie: these 'function' have multiple mathematicaly correct results and various math system are giving you different (correct) results, which results in a different output plot.
Furthemore, depending on the complex setting of Prime, you can get different graphs on the same machine!
cyrille
