Re: HP-41(CL): The easiest way... OK, how about you Windows guys? Message #9 Posted by Raymond Wiker on 5 Dec 2013, 12:55 a.m., in response to message #8 by Geir Isene
To those of you who are still on Windows; How do you transfer FOCAL programs from your PC to your HP-41?
If you mean FOCAL and not "RAW", I'd generate bar codes and use the bar code wand to enter the code into the calculator. If I had the need to transfer RAW, I'd look into using bar codes for that, too - I think it should be possible to replace the "code generation" part with something that takes RAW data (possibly encoded as hex strings, base64, whatever).
Note that this may or may not be PC-specific; "my" barcode generator only requires a reasonably up-to-date web browser.
Edited: 5 Dec 2013, 12:56 a.m.
