Re: New Bug in new Firmware Message #6 Posted by Stefan Dröge (Germany) on 3 Dec 2013, 9:52 a.m., in response to message #2 by Tim Wessman
Sorry, I found a new bug in the new firmware :) The bug does not occur with the old firmware (verfied with the emulator)
It seems to have something to do with the uppercase "E" EEX symbol:
On the CAS screen insert a constant that uses the "E" symbol e.g.
Shift -> Units -> Const -> Physics -> Epsilon0
Press enter. An error message appears which repeats the constant's value.
Playing around with the value (deleting decimal digits, altering the exponent) lead to the insight that the uppercase "E" in 8.8541878176E-12 is the problem.
However: Interestingly there is no problem when I enter e.g. 8.8E33 on the home screen and then switch to CAS and press enter.
All tests were done on a wiped calculator. So it should not be a problem with some special settings.
P.S: It would be very nice if future firmware versions would have the possibility to insert constants symbolic.
Thanks for the new firmware!
