Re: HP Prime - Reset methods Message #2 Posted by Joe Horn on 21 Nov 2013, 12:15 a.m., in response to message #1 by bluesun08
I read several reset methods:
a) Reset hole (back of the unit)
b) On-Symb key
c) "F,C,O"-Reset
d) Esc+Apps+On
e) Reset(which?) + Backspace
Questions:
1. What are the effects of these particular reset methods?
2. Are there other reset methods?
Here's my current understanding:
a & b: Simple warmstart, recovers keyboard control, restores most of RAM to the state it was in at the last power-down, thus possibly losing subsequent changes.
c: Displays the EA656 DIAGNOSTIC menu. Mostly used for resetting memory to factory condition ("Format Disk C") by pressing 4, 3, Enter, Esc, 9. This clears EVERYTHING, even the current language setting. (But not the OS & boot loader, obviously!) Many other operations are available in this undocumented diagnostic menu.
d: Clears most of memory, but maintains a few basic things (e.g. calculator name, color theme, language). Same as emulator's "Calculator Reset", or "Clear all memory" in the Memory Manager (which does NOT clear ALL memory).
e: Holding down the backspace key during a warmstart supposedly prevents some things from loading. If the machine crashes immediately upon turn-on, try holding down the backspace key.
Note: The F+C+O reset can be performed several ways, including holding down F+C+O during a warmstart, or simply holding down F+C+O while turning the calculator on.
I don't know of any other reset methods.
