Simple Tetris. free for you to improve on Message #1 Posted by cyrille de Brébisson on 20 Nov 2013, 2:43 a.m.
Around 80 lines of code... not bad for an interractive game..
Among the first things that needs to be improved (appart from the graphics!) is the key handling... specificaly, the wait should be cut in sub waits with key checking to allow more movements per 'cycles'...
DoesNotFit(game, piece, p) // return true if piece does not fit
begin
local j;
if game(im(p), re(p)) then return 1; end;
for j:=1 to size(piece) do
p:= p+piece(j);
end;
return 0;
end;
EXPORT Tetris()
local game= makemat(J=1 or J=12 or I=1 or I=25,25,12), pause=0.200, score= 0;
local shapes= {{(1, 0), (0, 1), (-1, 0)},
{(1, 0), (0, 1), (1, 0)},
{(-1, 0), (0, 1), (-1, 0)},
{(1, 0), (1, 0), (0, 1)},
{(-1, 0), (-1, 0), (0, 1)},
{(1, 0), (1, 0), (-1, 1)},
{(1, 0), (1, 0), (1, 0)}}; // Bar
while 1 do
local piece=shapes(randint(6)+1), p=(5,2), i, j; // get a random piece
if DoesNotFit(game, piece, p) then return score; end; // test if we lose
// create background
dimgrob_p(G1, 320, 240);
dimgrob_p(G2, 320, 240);
line_p(G1,99, 0, 99, 232, #FF); line_p(G1, 99, 232, 202, 232, #FF); line_p(G1,202, 232, 202, 0, #FF);
for i:=1 to 23 do
for j:=1 to 10 do
if game(i+1,j+1) then rect_p(G1, j*10+91, i*10-9, j*10+100, i*10, #0); end;
end;
end;
while NOT DoesNotFit(game, piece, p) do
// Draw the background on back buffer
blit_p(G2, G1);
// draw the piece
i:=p;
rect_p(G2, i*10-(-81,19), i*10-(-90,10), #0);
i:= i+piece(j);
end;
// draw backbuffer on screen
blit_p(G2);
// pause
wait(pause);
// keys?
if IsKeyDown(37) then if NOT DoesNotFit(game, piece, p-1) then p:= p-1; end; end;
if IsKeyDown(39) then if NOT DoesNotFit(game, piece, p+1) then p:= p+1; end; end;
if IsKeyDown(33) then
local rotate= piece*(0, 1);
if NOT DoesNotFit(game, rotate, p) then piece:= rotate; end;
end;
// try to go down...
if DoesNotFit(game, piece, p+(0,1)) then break; else p:= p+(0,1); end;
end;
// put piece in game!
game(im(p), re(p)):= 1;
p:= p+piece(j);
game(im(p), re(p)):=1;
end;
// remove lines?
for i:=24 downto 2 do
if game(i)=[1,1,1,1,1,1,1,1,1,1,1,1] then
for j:=i-1 downto 2 do game(j+1):= game(j); end;
game(2):= [1,0,0,0,0,0,0,0,0,0,0,1];
score:= score+1;
i:= i+1;
end;
end;
// faster!
pause:= pause-0.001;
end;
Edited: 20 Nov 2013, 2:54 a.m.
