Re: [HP-Prime] - Missing confirmation before deletion Message #9 Posted by Tim Wessman on 13 Nov 2013, 4:41 p.m., in response to message #8 by Jean-Michel
Honestly, I haven't heard of anyone (apart from the very first week or two of use) hitting buttons instead of the screen. It seems to go away quickly as you get use to the touchscreen. My guess is that was text left in from the 39gII document, that was later removed as they were checking and discovered it was no longer the case. I don't know if it was an intentional removal or just a side impact of creating a new system wide 2d text editor.
Since the same editor used in the command line is also used for notes/programs, adding in a clear confirmation would also impact the normal command line. Not saying it can't be done, but it is a bit more work to have it only appear in those places.
Another option might be that if the command line has > then a certain number of characters, a confirmation would *also* be helpful for that and it should be in by default for that case.
Anyway, it is in the list of things to look at. Thanks for the suggestion/report.
TW
