Re: Shutdown with the Apps key and more than 10 variables in a program. Message #5 Posted by Han on 5 Nov 2013, 12:18 p.m., in response to message #4 by Davi Ribeiro de Oliveira
Ok Michael.
Solved the problem of the Apps key. Thank you very much, the machine is functioning normally.
More help: how to enter a program at the command line and then run it? Typed as guidance and did not work. Can indicate where has this guidance in the guide or give me the complete command line?
Thank You
David
Type this code in using the program editor
EXPORT MYPROG(x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12,x13,x14,x15,x16)
RETURN(x1+x2+x3+x4+x5+x6+x7+x8+x9+x10+x11+x12+x13+x14+x15+x16)
Exit the program editor (press the [Home] key). Now type:
MYPROG(1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16)
and the display should show 136. Avoid using capital letters like A, B, C, D, ... , Y, Z as local variables because these may conflict with the built-in global variables.
Edited: 5 Nov 2013, 12:19 p.m.
