Re: HP Prime Crash Message #6 Posted by Michael de Estrada on 4 Nov 2013, 5:16 p.m., in response to message #5 by bluesun08
I'd suggest connecting the calculator to the AC charger and leave it turned on. According to the User Guide, Exam Mode should timeout after a maximum of 8 hours after which time you should regain control of the calculator and be able to manually adjust all settings, including the clock.
If this doesn't work, you may have to reformat the flash drive, which will restore the calculator operating system, but will erase any data and programs you had stored on it.
It's really unfortunate that there's no way to backup the calculator other than on a pc via the connectivity kit. You could, I suppose, buy a second Prime and a micro USB to micro USB cable, and use the second Prime to backup the first.
Edited: 4 Nov 2013, 5:21 p.m.
