More undocumented programming limitations in the HP Prime Message #1 Posted by Michael de Estrada on 3 Nov 2013, 1:23 p.m.
Well, I've found another undocumented limitation with PPL programming. It seems that the LOCAL declaration is limited to a paltry 7 entries, after which it will return a syntax error message when the program is checked. Beyond 7 entries it is necessary a add a second LOCAL declaration for the additional entries, and even more declarations if there are more than 14 entries. This limitation is neither mentioned in the Prime Help nor in the User Guide. Also, the calculator message "syntax error" is really not pertinent, since the statement is syntactically correct, and the message should be something like "exceeds maximum number of 7 entries". A lot of work is needed in documenting the usage of PPL.
Edit. Well after adding a second LOCAL statement, it now appears that the limitation has become 8 entries per LOCAL statement. This is totally confusing.
Edited: 3 Nov 2013, 1:36 p.m.
