Re: [HP PRIME] It's Time and Complexity Message #31 Posted by DeboT on 5 Nov 2013, 5:49 a.m., in response to message #5 by Jake Schwartz
Also since the Corvallis, Oregon calculator organization probably had two orders of magnitude higher financial commitment from HP as compared to now...
So if HP management does not consider the calculator development seriously, then why should anyone seriously consider buying an HP calculator?
Releasing buggy software is not acceptable, it puts people off. OK, so most SW has bugs when first released, but they should be minor and have very little effect in daily use. Most top-end companies release fixes within days of discovering a bug that affects daily use!
My experience on the 39gii is very similar to this post (message 4).
I purchased a 39Gii in August this year, it still had the buggy May 2012 firmware installed! Well, at least that would restart when it encountered a problem it could not solve, the Sept 2012 firmware just hangs solid! It requires a battery pull!! Imagine that, having to take out your batteries in an exam because the calculator hangs? I would rather it crash or give up or error, but just sit there indefinitely with the busy indicator? What a laugh!
Remember my comment above on how quickly top-end companies release bug-fixes? It is more than a year since an update for the 39Gii, despite known problems (e.g. CASE not working, SUB with lists causing indefinite hang, display bug with 10^-x). The most serious problem is that of the "indefinite hang with busy indicator". I have had several problems with this (recently so bad that I had to keep the battery cover removed - trying a local defined list in a program).
So after the 39gii experience, I will never consider HP calculators again, whether for educational, scientific or engineering.
Many posters here are people with HP stars in their eyes, and say "it's OK because we can update with fixed firmware". There are only a few that post criticisms. This does not represent the majority of the population, as those that couldn't be bothered with the Prime, also couldn't be bothered to post. They will vote with their wallet. They will look at their mates' Prime and after the initial "ooh, ahh" they go "hum, ha" and "maybe not for me". You see, when I was in college I got an HP because compared to the TI's and Casio's, they "just worked". Now sadly the opposite is true! Let us remember that HP is trying to RE-capture a market share! You need something striking AND close to perfect to do that.
Jake, as your post painfully points out (perhaps unintentionally), HP management is not putting the resources in to really knock HP calculators back onto the world stage! Goodbye HP calculators.
