Re: HP Prime: Pass "Long" Integers to a Program Message #7 Posted by Helge Gabert on 3 Nov 2013, 1:12 p.m., in response to message #6 by Helge Gabert
One more thing:
On the HP50G, the premise is that everything is an object and obeys the same rules. So, if your argument to a program is a long integer, a matrix, list, binary, complex number, algebraic expression, whatever - - you can pass it to your program with
<< -> k
<< do something here with k >>
and everything works beautifully.
On the Prime, however, you constantly need to be on the guard. Data types get converted, you need to be careful with CAS programs vs. Home programs, the program catalog "run" command only accepts reals, CAS commands don't accept functions you define with the "Define" key - - error message "Unmatch control word", RPN is an afterthought, lists can only have 999 elements, no compiled local variables, symbolic elements cannot be entered in to the matrix editor, etc. - -I could go on and on.
It seems to me that the "unifying" idea behind the Prime are the apps - - and that is OK for students, but how often do I use, say, the "Linear Explorer"? Even the "Solve" app is rudimentary (no complex solutions, and for more than univariate problems, the diagnostics are missing) and could be a lot better - - look, for example, at the "Solvesys" library for the 50G, which has been around for years - - I can't believe that HP couldn't take a clue from that.
Anyway, enough ranting - - I do like the speed of the Prime and the colors are great - - hopefully, things will flesh out over time. And using it interactively, it can be fun!
