HP-41 Plastic Slide Message #1 Posted by mbrethen on 31 Oct 2013, 6:39 p.m.
Over its production run, did HP change the plastic slide that holds the overlays? I have a CV (circa 1984) which does not have a spring return. The plastic slide is snug and clicks into place when you slide it up. I have not found any info about this online.
Edited: 31 Oct 2013, 7:35 p.m.
