collect( (-3*a*x^2 +7*a*x^1 -2*a-3*b*x^2 + 7*b*x^1 -2*b+3*x^3 -7*x^2 + 2*x^1)/3 ) ; [ENTER] => -1.*(x-2.)*(x-0.333333333333)*(a-x+b)
factor( (-3*a*x^2 +7*a*x^1 -2*a-3*b*x^2 + 7*b*x^1 -2*b+3*x^3 -7*x^2 + 2*x^1)/3 ) ; [ENTER] => -1.*(x-2.)*(x-0.333333333333)*(a-x+b)
collect( (-3*a*x^2 +7*a*x^1 -2*a-3*b*x^2 + 7*b*x^1 -2*b+3*x^3 -7*x^2 + 2*x^1)/3 ) ; [ENTER] => (x-2)*(3*x-1)*(x-a-b)/3
factor( (-3*a*x^2 +7*a*x^1 -2*a-3*b*x^2 + 7*b*x^1 -2*b+3*x^3 -7*x^2 + 2*x^1)/3 ) ; [ENTER] => (x-2)*(3*x-1)*(x-a-b)/3
collectPolTerms( (-3*a*x^2 +7*a*x^1 -2*a-3*b*x^2 + 7*b*x^1 -2*b+3*x^3 -7*x^2 + 2*x^1)/3, x ) ; =>
main( ):=
CONJUGATE() := BEGIN true; END;
SYMBOLIC() := BEGIN true; END;
RETURN( OK );
collectPolTerms( Poly, Var ):=
LOCAL FlagBadArg;
FlagBadArg:= "false";
IF NOT( POS( { "AlgExpression", "Equation", "Identifier", "RealNumber", "IntegerNumber",
"AlgComplexNumber", "RationalNumber", "RatComplexNumber" }, getType( Poly ) ) )
THEN
FlagBadArg := "true";
IF NOT( MSGBOX( "collectPolTerms:Invalid Data Type for 1 arg", true ) )
THEN kill;
IF NOT( getType( Var ) == "Identifier" )
THEN
IF NOT( MSGBOX( "collectPolTerms:Invalid Data Type for 2 arg", true ) )
THEN kill;
ELSE kill;
IF FlagBadArg == "false"
THEN
IF isEquation( Poly ) == "true"
THEN
Poly := toEq( eqToExpr );
RETURN( sum( coeff( Poly, Var ) .* seq( Var^k, k, degree( Poly, Var ), 0, 1 ) ));
ELSE
RETURN( "Invalid Data Type" );
getType( Data0 ):=
LOCAL TypeN, TypeID, RealType, ObjStr;
TypeID := type( Data0 );
IFERR
TYPE( Data0 )
THEN
RealType := "ERROR";
ObjStr := "ERROR";
ELSE
TypeN := TYPE( Data0 );
ObjStr := STRING( Data0 );
CASE
IF TypeID == DOM_FLOAT
THEN
RealType := "RealNumber";
IF TypeID == DOM_INT
THEN
RealType := "IntegerNumber";
IF TypeID == DOM_COMPLEX
THEN
IF inString( ObjStr,"(" ) >= 1
THEN
RealType := "CooComplexNumber";
ELSE
RealType := "AlgComplexNumber";
IF TypeID == DOM_RAT
THEN
IF inString( ObjStr, string( i ) ) >= 1
THEN
RealType := "RatComplexNumber";
ELSE
RealType := "RationalNumber";
IF TypeID == DOM_SYMBOLIC
THEN
IF inString( string( Data0 ), "=" ) >= 1
THEN
RealType := "Equation";
ELSE
RealType := "AlgExpression";
IF TypeID == DOM_IDENT
THEN
RealType := "Identifier";
IF TypeID == DOM_STRING
THEN
RealType := "String";
IF TypeID == DOM_FUNC
THEN
RealType := "Function";
IF TypeID == DOM_LIST
THEN
CASE
IF inString( ObjStr, "poly1[" ) >= 1
THEN
RealType := "PolynomialCoeff";
IF inString( ObjStr, "set[" )>= 1
THEN
RealType := "Set";
IF inString( ObjStr, "[[" ) >= 1
THEN
RealType := "Matrix";
IF inString( ObjStr, "[" ) >= 1
THEN
RealType := "Vector";
IF inString( ObjStr, "{" ) >= 1 OR inString( ObjStr, "{[" ) >= 1
THEN
RealType := "List";
DEFAULT RealType := "Other Type LIST";
IF TypeN == 8
THEN
RealType := "Unit";
IF TypeID == 21
THEN
RealType := "HMS";
IF TypeN == 1
THEN
CASE
IF inString( ObjStr, "d" ) >= 1
THEN
RealType := "DecNumber";
IF inString( ObjStr, "b" ) >= 1
THEN
RealType := "BinNumber";
IF inString( ObjStr, "h" ) >= 1
THEN
RealType := "HexNumber";
IF inString( ObjStr, "o" ) >= 1
THEN
RealType := "OctNumber";
DEFAULT RealType := "Other Base";
DEFAULT RealType := "Other";
RETURN( RealType );
partString( Str0, StrP ):=
LOCAL FlagBadArg;
IF NOT( ( getType( Str0 ) == "String" ) AND ( NOT( Str0 == "" ) ) )
THEN
IF NOT( MSGBOX( "partString: Invalid Data Type for 1 Arg", true ) )
THEN kill;
IF NOT( ( getType( StrP ) == "String" ) AND ( NOT( StrP == "" ) ) )
THEN
IF NOT( MSGBOX( "partString: Invalid Data Type for 2 Arg", true ) )
THEN kill;
ELSE kill;
THEN
RETURN( convertToRealBoolean( inString( Str0, StrP ) ) );
ELSE
convertToRealBoolean( Object0 ):=
IF isBooleanDataType( Object0 ) == "true"
THEN
IF getType( Object0 ) == "String"
THEN
Object0 := expr( Object0 );
IF Object0 <= 0
THEN
RETURN( "false" );
ELSE
RETURN( "true" );
ELSE
IF NOT( MSGBOX( "convertToRealBoolean: Invalid Data Type", true ) )
THEN kill;
ELSE kill;
isBooleanDataType( Object ):=
LOCAL FlagBadArg, ObjectType;
ObjectType := getType( Object );
IF NOT( POS( { "RealNumber", "IntegerNumber", "RationalNumber", "String" }, ObjectType ) )
THEN
IF FlagBadArg == "true"
THEN
RETURN( "false" );
ELSE
IF ObjectType == "String"
THEN
ObjectType:= expr( Object );
IF isNumber( ObjectType ) == "true"
THEN RETURN( "true" );
ELSE RETURN( "false" );
ELSE
RETURN( "true" );
isNumber( Object ):=
LOCAL ObjectType;
ObjectType:= getType( Object );
IF POS( { "RealNumber", "IntegerNumber", "RationalNumber" }, ObjectType )
THEN
RETURN( "true" );
ELSE
RETURN( "false" );
isComplexNumber( Object ):=
LOCAL ObjectType;
IF POS( { "CooComplexNumber", "AlgComplexNumber", "RatComplexNumber" }, ObjectType )
THEN
RETURN( "true" );
ELSE
RETURN( "false" );
isEquation( Object ):=
LOCAL FitObject;
IFERR
EVAL( Object );
THEN
FitObject := Object;
ELSE
FitObject := EVAL( Object );
IF getType( FitObject ) == "Equation"
THEN
RETURN( "true" );
ELSE
RETURN( "false" );
eqToExpr( Eq ):=
IF isEquation( Eq ) == "true"
THEN
RETURN( expr( replace( string( Eq ), "=" , "-(" ) + ")" ) );
ELSE
RETURN( Eq );
transpose2( Array, Test0 ):=
LOCAL FlagBadArg;
IF NOT( POS( { "Vector", "Matrix" }, getType( Array ) ) )
THEN
IF NOT( MSGBOX( "transpose2: Invalid Data Type for 1 arg", true ) )
THEN kill;
IF NOT( isBooleanDataType( Test0 ) == "true" )
THEN
IF NOT( MSGBOX( "transpose2: Invalid Data Type for 2 arg", true ) )
THEN kill;
ELSE kill;
ELSE
Test0 := convertToRealBoolean( Test0 );
THEN
IF Test0 == "true"
THEN
RETURN( TRN( Array ) );
ELSE
RETURN( transpose( Array ) );
ELSE
toPoly1var( Object, Var, Test ):=
LOCAL FlagBadArg, FitPoly, ObjectType;
"AlgComplexNumber", "RatComplexNumber", "RationalNumber", "PolynomialCoeff", "Vector" }, ObjectType ) )
THEN
IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 1 arg", true ) )
THEN kill;
THEN
IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 2 arg", true ) )
THEN kill;
IF NOT( isBooleanDataType( Test ) == "true" )
THEN
IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 3 arg", true ) )
THEN kill;
ELSE kill;
ELSE
Test := convertToRealBoolean( Test );
THEN
CASE
IF ObjectType == "PolynomialCoeff"
THEN
IF Test == "true"
THEN
RETURN( poly2symb( ObjectType, Var ) );
ELSE
RETURN( ObjectType );
IF ObjectType == "Vector"
THEN
FitPoly := expr( "poly1" + Object );
IF Test == "true"
THEN
RETURN( poly2symb( FitPoly, Var ) );
ELSE
RETURN( FitPoly );
IF isEquation( Object ) == "true"
THEN
FitPoly := eqToExpr( Object );
IF Test == "false"
THEN
RETURN( symb2poly( FitPoly, Var ) );
ELSE
RETURN( FitPoly );
DEFAULT
IF Test == "false"
THEN
RETURN( symb2poly( Object, Var ) );
ELSE
RETURN( Object );
ELSE
polyCoeffToArray( Poly ):=
LOCAL FlagBadArg;
IF NOT( POS( { PolynomialCoeff }, getType( Poly ) ) )
THEN
IF NOT( MSGBOX( "polyCoeffToArray: Invalid Data Type for 1 arg", true ) )
THEN kill;
THEN
RETURN := expr( replace( string( Poly ), "poly1" , "" ) );
ELSE
randPoly2( Pdim, Il, Sl, Var, Test ):=
LOCAL Rp;
Rp := randPoly( Pdim, expr( Il + ".." + Sl ) );
RETURN( toPoly1var( Rp, Var, Test ));
polyToCoeff( Poly, Var ):=
LOCAL PolyFnt, Out, Cnt0, Temp0;
purge( Pol );
THEN
Poly := eqToExpr( Poly );
expr( Pol(Var)+":="+string( Poly ) );
Out := MAKELIST( 0, Cnt1, degree( Poly ), 0, 1 );
Cnt0:=0;
WHILE Pol(Var) <> 0 DO
Temp0 := Pol(Var) / (Cnt0!) ;
Out[ Cnt0 ] := ( Temp0 | Var=0 );
Cnt0 := Cnt0 + 1;
Pol(Var) := diff( Pol(Var), Var);
Out := expr( "poly1[" + string( REVERSE(Out) ) + "]");
RETURN( Out );
