Re: HP Prime 'where' function Message #12 Posted by Joe Horn on 29 Oct 2013, 6:56 p.m., in response to message #11 by bluesun08
Quote: An ideal place for the "|"-sign would be SHIFT 6.
That would require three strokes (shift, 6, |). Its current location only requires two (template, |).
Hey, I just noticed that both the 50g and Prime require exactly the same finger travel to press "|". On the 50g, the distance between the right-shift key and the TOOL key is 3 inches (7.5 cm), and on the Prime, the distance between the template key and the "|" on the screen is exactly the same. Same number of presses, and same finger travel. Hmmm.
