Re: suggestions for HP prime Message #3 Posted by Joe Horn on 28 Oct 2013, 8:27 a.m., in response to message #1 by dietmar13
Quote: put the '-sign useable in diff-equations (is the ´-sign in this choice-box usefull for anything?) ...
The single-quote [ ' ] is available now via Shift ( ) backspace.
I think that the acute-accent forward-quote [ ´ ] is only used when entering minutes in hours-minutes-seconds (or degrees-minutes-seconds). The Shift fraction button can be used for that too.
Quote: ... and the %-sign in the shift-9 choice-box.
Good idea.
Quote: and please give us a syntax/variable autocompletion on shift-hold right-cursor (i would suspect that this can be done only by HP).
That would be awesome.
