Re: HP PRIME - APP Programing question Message #3 Posted by dg1969 on 27 Oct 2013, 10:23 a.m., in response to message #2 by Han
Thanks Han for your answer.
In fact I have try to place code inside the BEGIN END block of the function APP.
EXPORT Function()
RETURN(2*5);
Then launch Function from the command line... I have 10 in response... But the calculator freeze When I try to use APP key or when I try to access to function code with the program editor in order to remove the code... I have to use the reset hole...
