PRIME Spreadsheet RPN Problem Message #1 Posted by Dougggg on 24 Oct 2013, 8:01 p.m.
I can confirm there is a issue using with Prime set to RPN, I enter 3 Cells and either odd numbers or erros showed up in the cells, went to type another the Prime re-booted, however strangely a program, I downloaded HP_ELEMENTS now wont run when I try it gives an error "Invalid Input" but when I run check in the editor it says no errors in program, anything else to do?
