Re: Connectivty Kit for HP Prime needs an "Import Program" Command Message #2 Posted by Han on 23 Oct 2013, 10:02 a.m., in response to message #1 by Eddie W. Shore
I think the emulator has several instances to which it falls back in case of a crash/warmstart.
C:\Documents and Settings\<user>\Application Data\HP_Prime
and similar folders (e.g. ends with HP_Prime_1). You can either place it in all of them, or close the emulator and open it repeatedly until it loads the instance in which you saved the program. If this still doesn't work, then I'm not sure what's going on =/
But yes, drag and drop would be a welcome feature.
Edited: 23 Oct 2013, 10:05 a.m.
