Re: What does the Send menu key in the Apps window do? Message #4 Posted by Tim Wessman on 23 Oct 2013, 10:56 a.m., in response to message #3 by Michael de Estrada
The biggest difference in terms of the way to think about communication on the Prime vs the 50g is that it is a *push* model. The receiver never needs to accept a communication, or specify "lets go into communication mode", or similar things. If the unit is connected to something, that something on the other end can send data to it.
Everywhere you can access a data file of any kind (note, program, app, etc), there is a simple button to send that item along to the device on the other end.
The connkit does have a special "pull" capability, but internally it really is just a "hey, send me all your data" command with a much larger response then normal. :-)
TW
