Re: Does RPN entry mode cause the Prime keyboard to lock up ? Message #14 Posted by Michael de Estrada on 22 Oct 2013, 11:10 p.m., in response to message #13 by Michael de Estrada
Well, I finally got it to lock up and lose keyboard control while connected to the USB port and set to algebraic entry mode, so maybe there's more to this than RPN problems. I was inside a spreadsheet when this occurred. Also, earlier today when I first started the PC with the Prime connected, then started the emulator, the emulator crashed and then the connectivity kit crashed when I started it. I turned off the Prime, then restarted the connectivity kit, emulator and Prime in that order and all was fine. Also, just now the Prime shut itself off, even though it was still connected to the USB, whereas it normally remains ON indefinitely.
