HP-65 short circuit Message #1 Posted by Ignacio Sánchez Reig on 21 Oct 2013, 3:27 a.m.
Dear friends,
last week I bought a working HP-65. The card reader wheel was obviously in bad state. This week-end I proceeded to remove the gummy wheel and replace it. I have done this more than fifteen times in 67 & 41c card readers. I was very surprised when, (after replacing the wheel and ensambling the calculator back) I tested the calculator and it was short circuited (continuity between + and -). I tried to identify the origin of the short circuit without success.
-I checked the wires/connections, etc...all seems fine.
-I removed the main board: the short circuit was still there.
-I disconneceted the card reader motor (by unsoldering the red wire): the short circuit was still there. I was a bit surprised also because I realised that there is continuity in the capacitor installed in the motor (I firstly thought this was was the problem, is this normal?)
I would appreciate very much your ideas or comments to try to repair this jewel. Is it possible to get a copy of the service manual? I know there are some reverse engineering diagrams from Tony Duell, where can I get them?
Thank you in advance.
Kind regards
Ignacio
Edited: 21 Oct 2013, 3:34 a.m.
