Re: Proper location for files on the PC for Connectivity Kit ,etc. Message #5 Posted by Geoff Quickfall on 20 Oct 2013, 2:15 p.m., in response to message #4 by Harold A Climer
At the moment the real calc does not see them unless you copy the file to the calc.
I have been having problems with the emulator and connectivity kit. The emulator crashes to often to call it a stable platform for storing programs. And the connectivity kit has a bug where any info stored in the content section is lost when the kit is exited.
Therefore at the moment, (those issues are known by the team) i store my programs using notepad in my HP prime folder. If the emulator, content or real need it I can source it from my notepad file.
I know copy-drag-and-drop are being worked on but I don't know about plugging the real calc in and having it find the new App or program.
So as it is now, neither my emulator or real calc talk to one another and it is up to me to create, copy and paste from one to another. For example, I do a lot of programming on the real calc (NCC1701) on the flight deck and bring that calc home.
So I do the following at home:
1. Call up the connectivity kit.
2. Call up the emulator.
3. Plug in NCC1701.
4. Click on the Program tab and open the new program I want to paste.
5. Highlight-copy the program on the NCC1701.
4. Click on the 'Program tab of the emmulator.
5. Create a new program name in the emulator identical to the one I
Created on NCC1701.
6. Highlight-copy-paste the program from NCC1701
7. Repeat exercise with the Content tab/Program
8. Highlight-copy-paste the program from NCC1701 to a note pad file.
So I now have a notepad file, emulator copy and NCC1701 copy. Using the refresh calc button by selecting the name of the calculator in the kit and right clicking (emulator, NCC1701) you send anything you have done to the calcs. This is how a teacher can send to an entire class the contents of her/his Content folder.
Not seamless as you or I would like, but I am sure that it is in the works.
I just gave you my method for transferring back and forth!
Using the teacher function with fully operational connectivity kit will allow you to create programs or Apps in the Content tab and then send to the classroom, be that just your emulator and real or an entire class.
As I stated, although this function works, your info section only stays resident until you exit, so until this is fixed I will copy-paste.
Geoff
Edited: 20 Oct 2013, 2:20 p.m.
