Re: HMS commands Message #4 Posted by Geoff Quickfall on 14 Oct 2013, 4:26 p.m., in response to message #3 by Marcus von Cube, Germany
Yes, having trouble asking for an input on a program in a simple dceimal time representing a hexagesimal number.
best explained with an example:
Old school:
KEY PRESS DISPLAY
2.30 2.30
HR (HMS->) 2.50 This involves four keystrokes.
Converting back an forth was easy. Now to convert it is:
HMS->(2'30") 2.5 This involves nine keystrokes!
So in a nutshell I want the program to prompt for a hexagesimal number in the form of the old school format '2.3' and convert that to '2.5' decimal format. At the moment I need to input '2.3' by invoking the hexagesimal shift key and inputting with the tags, degrees, minutes and seconds.
Or is there a simple HMS command, (can't find it).
Cheers, Geoff
