HP Forum Archive 21
Formatting the app view message with bullets (dots)
Message #1 Posted by Geoff Quickfall on 14 Oct 2013, 1:30 a.m.
When creating and then editing the app info editor I add bullets and indents using the format bullet command.
This creates a nice indented bullet list.
Once I leave the app I have created and then return, the bullets and all my formatting disappears.
How do I make the bullet dots and indents permanent?
Re: Formatting the app view message with bullets (dots)
Message #2 Posted by Tim Wessman on 14 Oct 2013, 8:37 a.m.,
in response to message #1 by Geoff Quickfall
They should be. You are doing nothing wrong...
TW
Edited: 14 Oct 2013, 10:13 a.m.
Message #3 Posted by Marcus von Cube, Germany on 14 Oct 2013, 1:01 p.m.,
in response to message #2 by Tim Wessman
Formatting is lost if you change apps and return. :-(
Message #4 Posted by Geoff Quickfall on 14 Oct 2013, 4:28 p.m.,
in response to message #3 by Marcus von Cube, Germany
Okay, so shifting apps removes the formatting, to bad.
but I can work around by creating indents and using non disappearing characters like the asterisk or hyphen.
Thanks Tim and Marcus.
Re: more on bullets, dots and indents...
Message #5 Posted by Geoff Quickfall on 14 Oct 2013, 6:22 p.m.,
in response to message #4 by Geoff Quickfall
So here is how I get around the loss of the bullets when switching APPs
This is a suite of Aviation related programs dedicated to enhancing flight safety:
*Initialize: - invoke this program first to intitate degrees mode, clear memory.
*Input lat/lon: - this is the data input for start and finish waypoint co-ordinates for the Great Circle and Intermediate latitude programs. - prompts for start latitude and longitude and finish latitude and longitude.
*Great Circle: - calculates great circle distance in nautical miles and then displays initial true tack.
*Intermediate Latitude: - calculates the intermediate latitude given the start and finish waypoint co-ordinates input in the Input lat/lon routine above. Prompts for the intermediate longitude.
*Temperature correction: - prompts for airport temperature, airport altitude, final approach fix altitude, minimum descent altitude and missed approach point altitude. - calculates the corrected barometric altitudes for all three fixes.
*Fuel in tank - prompts for before fuel total, after fuel total, tender uplift and specific gravity. - calculates actual difference of fuel, % difference of fuel above or below and pass or fail if % difference is greater then 5%.
*QNH>31.00 inches: - prompts for actual QNH, MDA and VIS. - calculates the corrected MDA and VIS.
create indents with hyphens (+/-) and asterisk with the multiply sign and of course indents with spaces.
Geoff
Any chance of getting the bullets to be permanent on an update. Not a major bug but having re-inserted them a number of times thinking I was at fault it would be nice to have them!
;-D
Edited: 14 Oct 2013, 6:33 p.m.
