App production on Prime Message #1 Posted by Geoff Quickfall on 11 Oct 2013, 2:08 a.m.
Well i am trying,
I have a suite of programs that I would like to create an APP for. Each of the three routines that I have created all run independently as programs (thanks Eddie for helping).
I have entered the Dice program in and have been picking it apart to the point where I can create the an AVIATION APP which when VIEW is keyed displays the menu:
1 Start
2 Great Circle
3 Intermediate Latitude
4 Temperature Corrections
5 QNH>31.00
The start of the APP in edit appears as:
EXPORT Aviation()
VIEW "Start",START()
STARTVIEW(6,1);
VIEW "Great Circle",GREAT_CIRCLE()
HFormat:=1;
HDigits:=0;
HAngle:=1;
LOCAL D,B,lat1,lon1,lat2,lon2;
D:=ACOS(SIN(lat1)*SIN(lat2)+COS(lat1)*
COS(lat2)*COS(lon2-lon1))*60;
B:=ATAN((SIN(lon2-lon1)*COS(lat2))/
((COS(lat1)*SIN(lat2)-SIN(lat1)*COS(lat2)
*COS(lon2-lon1))))*-1;
IF B<0 THEN B:=B+360;
MSGBOX("Great Circle = " +D+" nautical miles");
MSGBOX("True Track = " +B+" degrees");
//followed by three more subroutines with the correct view commands.
This does not work ;-)
I cannot get the subroutines to run when the associated menu selection is made. Does the APP call the routines or must they be imbedded in the APP code. I notice that the Dice example has both calls and embedded code so I am at a loss.
In effect, what is the syntax after the start menu is created:
EXPORT Aviation()
STARTVIEW(6,1);
The independent routines are called:
GREAT_CIRCLE
INT_LAT
TMP_COR
thanks in advance,
Geoff
Edited: 11 Oct 2013, 2:25 a.m.
