Re: HP Prime: Slow turn off Message #2 Posted by Tim Wessman on 9 Oct 2013, 8:39 p.m., in response to message #1 by Paul D. Fox
45s definitely seems something strange is going on. Things can definitely slow down if there are HUGE data sets in lists,matrices, stack and so on, but I would not expect it to be that slow.
Is there any chance you run a "backup" from the connectivity kit and send it to me? I'd like to try a restore and see if I can replicate it.
Then you can probably try rebooting from the start with ON-APPS which should cleanup the main RAM.
TW
