Voyager keyboard issue Message #1 Posted by John Richards on 22 Sept 2013, 9:40 p.m.
I've recently acquired a Voyager that has an intermittent keyboard issue. There is one key in particular that often (not always) registers twice when I press it: once on the actual keypress, and then again when I release pressure on the key (seemingly on the way back up). This often (but not always) causes a failure on the keyboard self-test. The problem seems to be more pronounced for a firm keypress than for a light keypress: in particular, if I deliberately press the key all the way down, hold, and release, then the problem usually manifests itself; but if I quickly press and release the key, as I might in a series of rapid keystrokes, then the problem does not generally appear. All other keys seem to work fine, regardless of how I press them.
I'm wondering if anybody more knowledgeable can enlighten me: Is this a common failure mode for Voyagers? Is there any repair or solution, or is this a permanent condition?
Thanks,
