Re: wp34s binomial bug Message #2 Posted by Dieter on 22 Sept 2013, 2:02 p.m., in response to message #1 by Andrew Nikitin
First of all: which firmware version do you refer to?
I get the following results with v3.2 3405.
Just to be sure:
- "Binom" evaluates the lower CDF, i.e. the sum of all probabilities from k = 0...X
- "Binomu" evaluates the upper CDF, i.e. the sum of all probabilities from k = X...n
- "Binomp" evaluates the PDF, i.e. the single probability for k = X.
All this works fine here:
0,5 STO J
2 STO K
0 Binomp => pdf(0) = 0,25
1 Binomp => pdf(1) = 0,5
2 Binomp => pdf(2) = 0,25
0 Binom => lower cdf(0) = 0,25 (= pdf(0))
1 Binom => lower cdf(1) = 0,75 (= pdf(0) + pdf(1))
2 Binom => lower cdf(2) = 1 (= pdf(0) + pdf(1) + pdf(2))
0 Binomu => upper cdf(0) = 1 (= pdf(0) + pdf(1) + pdf(2))
1 Binomu => upper cdf(1) = 0,75 (= pdf(1) + pdf(2))
2 Binomu => upper cdf(2) = 0,25 (= pdf(2))
What do you get?
Dieter
Edited: 22 Sept 2013, 2:34 p.m.
