HP Forum Archive 21
HP Prime and Strings
Message #1 Posted by Han on 19 Sept 2013, 10:45 a.m.
Since the HP Prime is able to handle strings, is it possible to take strings and convert them into functions? I know back in the TI-85 there was such a command. Does/will the HP Prime have the ability to ask users to input a function to be used as a symbolic object like equations in the HP48 series?
I tried using the INPUT command but it seems to only accept numerical inputs.
Re: HP Prime and Strings
Message #2 Posted by Eddie W. Shore on 19 Sept 2013, 4:18 p.m.,
in response to message #1 by Han
What I found to be the most successful is to pass functions as strings as arguments. Example:
\\ calculate the numerical derivative of f(X) at X = N
EXPORT NDER(str1, N) BEGIN X:=N + .000001; D:=EXPR(str1) X:=N - .000001; D:= D - EXPR(str1); D:= D/(.000002); RETURN D; END;
EXPR - numerical evaluation of the string with the appropriate variables substituted.
f(X) = 3*e^X - 3*X^2. Find f'(1).
NDER("3*e^X - 3*X^2",1) returns 2.15484.
We could also use strings to store functions into graphing functions or equations. Example: "3*X+4" - > F1
Hope this helps, Eddie
Message #3 Posted by Gilles Carpentier on 19 Sept 2013, 4:54 p.m.,
INPUT allows all type of argument but you have put the right delimiters:
etc.
be carefull that A..Z variables are only numericals
The INPUT command is very powerfull (default value, on line help ...)
Message #4 Posted by Han on 19 Sept 2013, 5:00 p.m.,
in response to message #3 by Gilles Carpentier
Could you give me an example of how to ask the user to enter in a function that can be used as a function? Ideally I would like to have something like:
f(x,y)=
and have the user enter in a formula that can be used later on.
Message #5 Posted by Namir on 20 Sept 2013, 8:45 a.m.,
Here is an example of a Newton method that uses a string parameter sFx to pass a string image for a function:
EXPORT Newton(sFx,xguess,toler)
 LOCAL h,f,fp,diff;
 REPEAT
   h:=0.001*(ABS(xguess)+1);
   X:=xguess;
   f:=EXPR(sFx);
   X:=xguess+h;
   fp:=EXPR(sFx);
   diff:=h*f/(fp-f);
   xguess:=xguess-diff;
 UNTIL ABS(diff)<toler;
 RETURN xguess;
Samples calls are:
Newton("EXP(X)-3*X^2",-1,.00000001)
                                   -.458962267537
Newton("EXP(X)-3*X^2",1,.00000001)
                                   .910007572489
Newton("EXP(X)-3*X^2",4,.00000001)
                                    3.73307902863
The function uses the predefined variable X to store values of xguess (the guess for the root) and xguess+h, before calling function EXPR(sFx).
Namir
Message #6 Posted by Han on 20 Sept 2013, 10:11 a.m.,
in response to message #5 by Namir
Thank you for sharing your example, Namir. What I was looking for in particular, however, was an example on how to use INPUT in order to get a function. My goal is to create an interactive app, as opposed to a function like yours in which everything is entered at once. My attempt below results in an input-form-like interface (much like the HP48 series) but the default value is 0, and not a formula.
EXPORT EXAMPLE() BEGIN
INPUT(F,"Graph 3D","f(x,y)=","Enter the function to graph","1/390*(X^3*Y-X*Y^3");
If I do enter a new formula "X*Y" or 'X*Y' -- with the quotes -- I get a syntax error. If I take out the quotes, then (as expected), the value of F is whatever X*Y is equal to the moment the program was run. However, this is not what I want, since I cannot evaluate F at different values of X and Y later within my program.
Secondly, if such a procedure should work, then presumably F is a string. How would I then convert a string object into a function?
Edited: 20 Sept 2013, 10:16 a.m.
Message #7 Posted by Han on 20 Sept 2013, 10:18 a.m.,
etc.
To clarify, I was not referring the the arguments of the INPUT command. Instead the INPUT command -- when in use -- seems to only allow the user to enter in numerical values when the program is running.
