WP-34S: Some operator timings Message #1 Posted by Marcel Samek on 15 Sept 2013, 1:47 p.m.
Here is some data on operator speed. All of these were sampled at least 5 times (many were sampled 6 times) and below is the mean as well as the relative standard deviation of the samples.
These were all performed in decimal, single precision mode with a stack depth of 4.
To measure these I used a program that has a 30 second (using tick) loop with the operator being measured in the middle. I then run the same program with two of the operators in the loop, and then three of the operators, etc. The delta between adjacent runs measures the impact of adding a single operator to the loop.
The raw data can be found in this spreadsheet:
Libreoffice (OpenOffice?) Spreadsheet
It seems that the actual value of the number can have a significant value on the speed of the operations. For example for the 4 basic operations, I tested once using just whole numbers (but not in integer mode) and once using random values generated by the random number function.
For the the exponential functions, I use the value on the stack from the previous operation. This means that the range of values is huge and changes drastically. You can see that the impact that has on the relative standard deviation of the samples.
Operation Ops per second Milliseconds per op Relative Standard Dev
+ (whole #) 4,218 0.24 3.82%
+ (rand dec #) 2,729 0.37 3.60%
x (whole #) 4,115 0.24 1.33%
x (rand dec #) 2,134 0.47 4.36%
- (whole #) 4,421 0.23 0.93%
- (rand dec #) 3,402 0.29 3.14%
/ (whole #) 3,688 0.27 2.41%
/ (rand dec #) 979 1.02 1.65%
Sqrt 221 4.52 2.50%
R[v] 7,431 0.13 2.63%
R[^] 7,340 0.14 2.28%
y^x 35 28.75 1.43%
sin 47 21.06 3.57%
cos 46 21.84 5.40%
ln 21 47.41 7.60%
e^x 57 17.60 25.27%
1/X 1,068 0.94 1.97%
Edited: 15 Sept 2013, 2:14 p.m.
