Re: re-recording original cards Message #2 Posted by Paul Berger (Canada) on 15 Sept 2013, 9:14 a.m., in response to message #1 by aj04062
I re-recorded several cards for a 67/97 standard pack by grounding the write protect switch line. It would seem that the logic is it is looking at the order in which the motor switch and the write protect make, and if it detects the write protect switch first it assumes the card is writeable. This signal is on pin 3 of the CRC.
For a 41 the reader manual says you can override the write protect by setting flag 14.
