HP Forum Archive 21
50g piecewise functions
Message #1 Posted by Kurt Fankhauser on 15 Sept 2013, 3:20 a.m.
Is it possible to plot a piecewise function. I imagine that you would enter a separate Y= function for each segment, but how do you limit the domain of each function?
Also, how do you clear previous defined Y= functions? Every time I add a new one it increments the counter on it (so the latest one is displayed as Y11(x)=...). All previous functions are displayed in the CHOOS box. I want to clear them all. The CLEAR soft key only clears the functions listed in the PLOT-FUNCTION window, but not the CHOOS box.
Re: 50g piecewise functions
Message #2 Posted by Pier Aiello on 15 Sept 2013, 4:45 a.m.,
in response to message #1 by Kurt Fankhauser
For piecewise functions use IFTE (check best of on wiki4hp )
Message #3 Posted by Kurt Fankhauser on 15 Sept 2013, 8:00 p.m.,
in response to message #2 by Pier Aiello
Thanks Pier. I could not get the IFTE to work correctly with the Y= definition and plotting. The 50g thought for a while then gave an out-of-memory error. I read of others having similar issues.
Instead I found this post which suggested to multiply each segment by a logical domain relational expression:
https://groups.google.com/forum/#!topic/comp.sys.hp48/ZIv5UDxWcHA/discussion
For example, Y=(X^2)*(X>-1)(X<0)+(x-3)*(X>=0)(X<3)
That worked for me on my 50g with version 50-c revision 2.15 ROM.
Message #4 Posted by Pier Aiello on 16 Sept 2013, 2:36 a.m.,
in response to message #3 by Kurt Fankhauser
Good :)
Message #5 Posted by Simone Cerica on 16 Sept 2013, 1:20 p.m.,
IFTE BUG is present in ROM 2.15: https://groups.google.com/forum/#!topic/comp.sys.hp48/R3Pp62J_9SM
SC
Reset function number from the graph menu
Message #6 Posted by Pier Aiello on 15 Sept 2013, 8:42 a.m.,
For the functions in the graph menu, i just found (during my mining task on discussion boards) a really similar question. I'll add it on the page previously linked :)
http://h30499.www3.hp.com/t5/Calculators/impossible-to-reset-functions-in-graph-menus/td-p/5892643
Edited: 15 Sept 2013, 9:13 a.m.
Re: Reset function number from the graph menu
Message #7 Posted by Kurt Fankhauser on 15 Sept 2013, 8:01 p.m.,
in response to message #6 by Pier Aiello
Thanks Pier. Boy, could they have made this any more difficult?
