Re: HP-97 thermal head movement Message #5 Posted by davorin on 7 Sept 2013, 11:43 a.m., in response to message #4 by Paul Berger (Canada)
Just taking apart the printer now following this discussion:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv015.cgi?read=78799
Just wonder how this should work:
"Slide the carriage and leadscrew towards the right, Push the LH leadscrew bearing to the right (into the frame) and remove that too. Then 'unscrew' the leadscrew from the carriage and remove it through the left side of the printer frame."
To remove the RHS bearing it is okay...but the left side bearing?
Can push it into the frame but not remove it....
