Re: [Sigma]DAT on the 50G Message #2 Posted by Mark Hardman on 6 Sept 2013, 7:03 p.m., in response to message #1 by Matt Agajanian
You can CHOOSE any named matrix from the STAT applications. Once you choose the named matrix it is copied to [Sigma]DAT in the current directory. You can also EDIT [Sigma]DAT directly from a STAT application. If the variable does not exist in the current directory, it is created.
