Problem loading library into emulator Message #1 Posted by Tom Grydeland on 5 Sept 2013, 4:47 a.m.
Hi all,
I'm trying to use the assembler toolchain to ease my development somewhat, but I'm stuck at the point where I try to load the compiled library file into the emulator
(I use the provided wp34sgui.exe emulator under Wine)
The emulator appears unable to read any wp34s-lib.dat files, including the one that lives in the 'emulator' directory and which comes with the distribution. Whatever I enter manually ends up in a 'wp34s.dat' file and is read back correctly on the next restart.
I tried the workaround described by Les Wright in message #5, but the result was that the resulting wp34s.dat file could not be read either (another "Erased" message).
Any suggestions? (I am using rev. 3375)
--T
