Help with flashing HP30s Message #1 Posted by John Ioannidis on 1 Sept 2013, 11:52 p.m.
I'm trying to flash my HP30s and failing.
The setup:
* Programming cable (thank you, Gene)
* HP30s hooked to power supply (batteries are expensive)
* Atmel's sam-ba 2.12 on both Windows (vista) and Linux (ubuntu)
* Both hardware serial ports and USB serial adaptors.
None of the four combinations of port type and operating system seem to work. I select the port in sam-ba, select the right chip, and then I either get connection error (windows) or just indefinite wait (linux).
The instructions on the wiki mention sam-ba v2.9, but that's not available any more, and I don't see why that would make a difference.
I have an oscilloscope, a logic analyzer, and stuff like that, if debugging the problem involves using them.
Help?
Thanks,
/ji
