HP Forum Archive 21
SandMatrix Released - The trilogy is complete.
Message #1 Posted by Ángel Martin on 28 Aug 2013, 12:28 p.m.
The trilogy of Math modules is finally complete - including manuals and even real Overlays... (some still available)
- 41Z
- SandMath
- SandMatrix Manual
Enjoy!
PS.- Glad to see the 41 platform in such a good health.... now it's time for an extended break!
Edited: 28 Aug 2013, 12:29 p.m.
Re: SandMatrix Released - The trilogy is complete.
Message #2 Posted by gene wright on 30 Aug 2013, 11:36 a.m.,
in response to message #1 by Ángel Martin
Hey Angel. Thanks again for all you do.
I'd like to make a request / suggestion. :-)
How about showing us what a linear programming solution would look like using the SandMatrix module?
Solving something like:
Max 2x+4y
Subject to:
X + 3Y <= 5000
Y > 100
5X + Y <= 3000
X > 0
Y > 0
or such. You know, a classical optimization situation. Mix or max. I would think the coefficients could be stored in a matrix and a program given the mix or max choice and the number of variables, etc.
Why you?
Because you are da man. lol. :-)
Message #3 Posted by Ángel Martin on 30 Aug 2013, 12:55 p.m.,
in response to message #2 by gene wright
Sorry to disappoint you Gene but - I really think this assignment should be given to a more capable person. I wouldn't touch the linear optimization with a 12-foot pole, sort of always hated the SIMPLEX method and its derivatives :(
Suffice it to say some things we're good at and some others, err... you get the picture. Besides I'm in my break now, right?
Best, 'AM
Message #4 Posted by Marcel Samek on 30 Aug 2013, 5:35 p.m.,
Gene,
A little off-topic, but I'm trying to avoid real work.
A while back I wrote an implementation of the downhill simplex on the WP-34s. While that is generally used for non-linear optimization and has a host of caveats so it takes some massaging of the problem to get it to work, I nonetheless thought that I would give it a try with the example in your posting. It did give (within the tolerance value) the same solution as WolframAlpha (http://goo.gl/DP2BU). It took about 1000 iterations of the simplex. I ran it on the emulator so I am not sure how fast it is on the actual hardware.
I know that your question was about SandMatrix, but I thought that as a curiosity I would toss out my solution. To run it, you XEQ'NMS' with the number of variables (2) in X on the stack.
To use it, you have to code up a function called FUN which implements your function along with constraints. Because my implementation of the simplex assumes minimization, I changed the function value to be negated. To handle constraints in your example, I simply added a large "penalty" to the value of the function if a constraint is not met.
The NMS routine is not really quite ready to be called general purpose. It currently does not let you enter a starting point (it starts around 0,0) and it does not let you specify the tolerance which is currently hardwired. As soon as I clean those up one of these days I'll probably post it to the articles section.
However, the cool thing is that you can use it to minimize pretty much any type of function(s) with up to 8 variables. (All the traditional pitfalls of Nelder-Mead apply).
The listings below are meant to be run through the wp34s pre-processor / assembler.
Here is the FUN function that codes up your example:
LBL'FUN'
	LocR 4
STO .00 R[v] STO .01
/* big value for constraint hack */ 9 EEX 9 STO .03
/* evaluate 2x+4y but negate it so that we can minimize */ 2 RCL* .00 4 RCL* .01 + CHS STO .02
/* x+3y<=5000 */ 5 0 0 0 ENTER 3 RCL* .01 RCL+ .00 x>? Y XEQ 98
/* y>100 */ # 100 RCL .01 x<=? Y XEQ 98
/* 5x+y<=3000 */ 3 0 0 0 ENTER 5 RCL* .00 RCL+ .01 x>? Y XEQ 98
/* x > 0 */ 0 RCL .00 x<=? Y XEQ 98
/* y > 0 */ 0 RCL .01 x<=? Y XEQ 98
RCL .02 RTN
/* add error for unmet constraint*/ LBL 98 RCL .03 STO+ .02 RTN
And, here is the routine that does the solution. The comments make sense if you follow along with the amoeba code in Numerical Recipes.
    Nelder Mead  (Downhill Simplex) Method
    Multi-dimensional Minimization
Limitations: The code supports up to 8 dimensions, but you will probably not be able to use that many because of memory restrictions. It depends on the size of your evaluation function, register allocations, etc.
Global Register required: N^2 + N + 20
Stack: Requires a stack size of 8
Local Registers: (19 at deepest point) + (your eval function)
Prerequisite: You need to have a global function called 'FUN' which evaluates your function. The parameters to FUN are all passed on the stack. FUN needs to return one value (the evaluated function) in X.
Input: (X) Number of dimensions
Output: R03: F(x1, x2, x3....) at minimum R04: x1 R05: x2 R06: X3 ...
Configuration: This algorithm is known for getting stuck, especially if the function has lots of local minima or discontinuities. There is a configuration value that defines the maximum number of times it shall adjust the simplex before giving up. It defaults to 10000. If you wish to adjust this value, it is assigned to local register .06 right at the beginning of NMS.
The initial guess is aribrarily picked to be between 0 and 1 on all dimensions. If you wish to change the initial values, change the initValues function at LBL 31. Make sure that when that function returns it has valid values in the Y array for the simplex vertices you have chosen as the starting point.
Algorithm: This is a direct derivative of the Downhill Simplex method as described and implemented in Numerical Recipes. Please see that text for a description of how the algorithm works. */
LBL'NMS' LocR 007 REGS 100 SSIZE8 CLREGS
/* GREG[GREG_DIM] = NP; */ /* the number of dimensions got passed in in the X register */ STO 00
/* init NMAX */ 1 SDL 4 STO .06
/* initValues() */ XEQ 31
/* calcPsum(); */ XEQ 30
/* loop indefintely until exit condition */ /* for (;;) { */ mainLoop:: 0
/* LREG[LREG_AMOEBA_ILO] = 0; */ STO .02
/* GREG[GREG_IHI] = getY(0) > getY(1) ? (LREG[LREG_AMOEBA_INHI]=1,0) (LREG[LREG_AMOEBA_INHI]=0,1); */ 0 XEQ 20 1 XEQ 20 x<? Y JMP m1 0 STO .03 1 STO 02 JMP m2 m1:: 1 STO .03 0 STO 02
/* for (LREG[LREG_AMOEBA_I]=0; LREG[LREG_AMOEBA_I] < (int)GREG[GREG_DIM]+1; LREG[LREG_AMOEBA_I]++) { */ m2:: RCL 00 STO .00
mainLoop1:: RCL .00
/* if (getY((int)LREG[LREG_AMOEBA_I]) <= getY((int)LREG[LREG_AMOEBA_ILO])) */ XEQ 20 RCL .02 XEQ 20 x<? Y JMP m3
/* LREG[LREG_AMOEBA_ILO] = (int)LREG[LREG_AMOEBA_I]; */ RCL .00 STO .02
/* if (getY((int)LREG[LREG_AMOEBA_I]) > getY((int)GREG[GREG_IHI])) { */ m3:: RCL .00 XEQ 20 RCL 02 XEQ 20 x>=? Y JMP m4
/* LREG[LREG_AMOEBA_INHI]=(int)GREG[GREG_IHI]; */ RCL 02 STO .03
/* GREG[GREG_IHI]=LREG[LREG_AMOEBA_I]; */ RCL .00 STO 02 JMP m5
/* else if (getY((int)LREG[LREG_AMOEBA_I]) > getY((int)LREG[LREG_AMOEBA_INHI]) && LREG[LREG_AMOEBA_I] != GREG[GREG_IHI]) & */ m4:: RCL .00 XEQ 20 RCL .03 XEQ 20 x>=? Y JMP m5 RCL 02 RCL .00 x=? Y JMP m5
/* LREG[LREG_AMOEBA_INHI] = (int)LREG[LREG_AMOEBA_I]; */ STO .03
/* loop */ m5:: DSL .00 JMP mainLoop1
/* If tolerance is met, put the appropriate values into the output and be gone */ /* if (FTOL > 2.0*fabs(getY((int)GREG[02])- getY((int)LREG[02]))/ (fabs(getY((int)GREG[02]))+fabs(getY((int)LREG[02]))+TINY)) { */
RCL 02 XEQ 20 RCL .02 XEQ 20 - ABS RCL 02 XEQ 20 ABS RCL .02 XEQ 20 ABS + 1 SDR 10 + / 2 *
1 EEX CHS 1 6 x<=? Y JMP m6
/* GREG[GREG_SOLUTION_Y] = getY(LREG[LREG_AMOEBA_ILO]) */ RCL .02 XEQ 20 STO 03
/* for (LREG[LREG_AMOEBA_I]=0; LREG[LREG_AMOEBA_I] < GREG[GREG_DIM]; LREG[LREG_AMOEBA_I]++) { */ RCL 00 STO .00 DEC .00
/* GREG[04 + (int)LREG[00]] = getP((int)LREG[02], (int)LREG[00]); */ mainLoop2:: RCL .02 RCL .00 XEQ 24 4 RCL+ .00 x[<->] Y STO[->]Y
/* loop */ DSL .00 JMP mainLoop2
/* done */ GTO 99
/* if ((int)GREG[GREG_NUMCALLS] >= NMAX) */ m6:: RCL 01 x<? .06 JMP m7 CL[alpha] "Loop Max" VIEW[alpha] GTO 99
/* GREG[GREG_NUMCALLS] += 2; */ m7:: INC 01 INC 01
/* LREG[LREG_AMOEBA_YTRY]=amotry(-1.0); */ 1 CHS XEQ 26 STO .05
/* if (LREG[LREG_AMOEBA_YTRY] <= getY((int)LREG[LREG_AMOEBA_ILO])) */ RCL .02 XEQ 20 x<? Y JMP m8 2 XEQ 26 STO .05 JMP m9
/*if (LREG[LREG_AMOEBA_YTRY] >= getY((int)LREG[LREG_AMOEBA_INHI])) { */ m8:: RCL .03 XEQ 20 RCL .05 x<? Y JMP m10
/* LREG[LREG_AMOEBA_YSAVE] = getY((int)GREG[GREG_IHI]); */ RCL 02 XEQ 20 STO .04
/* LREG[LREG_AMOEBA_YTRY]=amotry(0.5); */ # 1/2 XEQ 26 STO .05
/* if (LREG[LREG_AMOEBA_YTRY] >= LREG[LREG_AMOEBA_YSAVE]) { */ RCL .04 x>? Y JMP m9
/* for (LREG[LREG_AMOEBA_I]=0; LREG[LREG_AMOEBA_I] < (int)GREG[GREG_DIM]+1 ;LREG[LREG_AMOEBA_I]++) { */ RCL 00 STO .00 mainLoop3:: RCL .00
/* if (LREG[LREG_AMOEBA_I] != (int)LREG[LREG_AMOEBA_ILO]) { */ x=? .02 JMP m11
/* for (LREG[LREG_AMOEBA_J] = 0; LREG[LREG_AMOEBA_J] < GREG[GREG_DIM]; LREG[LREG_AMOEBA_J]++) { */ RCL 00 STO .01 DEC .01 mainLoop4:: RCL .00
/*setPsum((int)LREG[LREG_AMOEBA_J], 0.5 * (getP((int)LREG[LREG_AMOEBA_I], (int)LREG[LREG_AMOEBA_J]) + getP((int)LREG[LREG_AMOEBA_ILO], (int)LREG[LREG_AMOEBA_J]))); */ RCL .01 XEQ 24 RCL .02 RCL .01 XEQ 24 + 2 / RCL .01 x[<->] Y XEQ 23
/* setP((int)LREG[LREG_AMOEBA_I], (int)LREG[LREG_AMOEBA_J], getPsum((int)LREG[LREG_AMOEBA_J])); */ RCL .00 RCL .01 RCL .01 XEQ 22 XEQ 25
/* increment and loop */ DSL .01 JMP mainLoop4
/* setY((int)LREG[LREG_AMOEBA_I], func(&GREG[(int)GREG_PSUM])); */ RCLS 12 XEQ'FUN' RCL .00 x[<->] Y XEQ 21
/* increment and loop */ m11:: DSL .00 JMP mainLoop3
/* GREG[GREG_NUMCALLS] += GREG[GREG_DIM]; */ RCL 00 STO+ 01 XEQ 30
JMP m9
m10:: DEC 01
/* back to the top of the loop */ m9:: JMP mainLoop
/* we are done */ LBL 99 STOP RTN
/* get the value pointed to by X, and lose the pointer from the stack */ LBL 00 RCL[->]X x[<->] Y DROP RTN
/* getY */ LBL 20 3 + XEQ 00 RTN
/* setY */ LBL 21 x[<->] Y 3 + x[<->] Y STO[->]Y
RTN
/* getPsum */ LBL 22 # 12 + XEQ 00 RTN
/* setPsum */ LBL 23 x[<->] Y # 12 + x[<->] Y STO[->]Y RTN
/* getP */ LBL 24 x[<->] Y RCL[times] 00 + # 20 + XEQ 00 RTN
/* setP */ LBL 25 [<->] ZYXT RCL[times] 00 + # 20 + x[<->] Y STO[->]Y RTN
/* amotry */ LBL 26 LocR 13 /* max NP of 8 */
/* LREG[LREG_AMOTRY_IN_FAC] = fac */ STO .04
/* LREG[LREG_AMOTRY_FAC1] = (1.0 - LREG[LREG_AMOTRY_IN_FAC]) / GREG[GREG_DIM]; */ CHS 1 + RCL 00 / STO .01
/* LREG[LREG_AMOTRY_FAC2] = LREG[LREG_AMOTRY_FAC1]-LREG[LREG_AMOTRY_IN_FAC]; */ RCL .04 - STO .02
/* for (LREG[LREG_AMOTRY_J] = 0; LREG[LREG_AMOTRY_J] < GREG[GREG_DIM]; LREG[LREG_AMOTRY_J]++) { {*/ RCL 00 STO .00 DEC .00
/* LREG[(int)(LREG_AMOTRY_PTRYOFFSET + LREG[LREG_AMOTRY_J])] = getPsum((int)LREG[LREG_AMOTRY_J]) * LREG[LREG_AMOTRY_FAC1] - getP((int)GREG[GREG_IHI], (int)LREG[LREG_AMOTRY_J]) * LREG[LREG_AMOTRY_FAC2]; */ amotryLoop1:: RCL .00 XEQ 22 RCL .01 [times] RCL 02 RCL .00 XEQ 24 RCL .02 [times] - RCL .00 # 117 + x[<->] Y STO[->]Y
/* increment the loop variable and loop */ DSL .00 JMP amotryLoop1
/*LREG[LREG_AMOTRY_YTRY] = func(&LREG[LREG_AMOTRY_PTRYOFFSET]); */ RCLS .05 XEQ'FUN' STO .03
/* if (LREG[LREG_AMOTRY_YTRY] < getY((int)GREG[GREG_IHI])) { { */ RCL 02 XEQ 20 RCL .03 x>=? Y JMP amotrycond1
/* setY((int)GREG[GREG_IHI], LREG[LREG_AMOTRY_YTRY]); */ RCL 02 RCL .03 XEQ 21
/* for (LREG[LREG_AMOTRY_J] = 0; LREG[LREG_AMOTRY_J] < GREG[GREG_DIM]; LREG[LREG_AMOTRY_J]++) { { */ RCL 00 STO .00 DEC .00
/* setPsum((int)LREG[LREG_AMOTRY_J], getPsum((int)LREG[LREG_AMOTRY_J]) + LREG[(int) (LREG_AMOTRY_PTRYOFFSET + LREG[LREG_AMOTRY_J])] - getP((int)GREG[GREG_IHI], (int)LREG[LREG_AMOTRY_J])); */ amotryLoop2:: RCL .00 ENTER
/* setPsum((int)LREG[LREG_AMOTRY_J], getPsum((int)LREG[LREG_AMOTRY_J]) + LREG[(int)(LREG_AMOTRY_PTRYOFFSET + LREG[LREG_AMOTRY_J])] - getP((int)GREG[GREG_IHI], (int)LREG[LREG_AMOTRY_J])); */ XEQ 22 # 117 RCL+ .00 XEQ 00 +
RCL 02 RCL .00 XEQ 24 -
XEQ 23
/* setP((int)GREG[GREG_IHI], (int)LREG[LREG_AMOTRY_J], LREG[(int)(LREG_AMOTRY_PTRYOFFSET + LREG[LREG_AMOTRY_J])]); */ RCL 02 RCL .00
# 117 RCL+ .00 XEQ 00 XEQ 25
/* increment the loop variable and loop */ DSL .00 JMP amotryLoop2
/* return LREG[LREG_AMOTRY_YTRY]; */ amotrycond1:: RCL .03 RTN
/* calcPsum */ LBL 30 LocR 3
/* for (LREG[LREG_CALCSUM_J] = 0; LREG[LREG_CALCSUM_J] < GREG[GREG_DIM]; LREG[LREG_CALCSUM_J]++) { */ RCL 00 STO .01 DEC .01 calcSumLoop1:: 0 /* for (LREG[LREG_CALCSUM_SUM] = 0.0, LREG[LREG_CALCSUM_I]=0; LREG[LREG_CALCSUM_I] < (int)GREG[GREG_DIM]+1; LREG[LREG_CALCSUM_I]++) */ STO .02 RCL 00 STO .00 calcSumLoop2:: RCL .00
/* LREG[LREG_CALCSUM_SUM] = LREG[LREG_CALCSUM_SUM] + getP((int)LREG[LREG_CALCSUM_I], (int)LREG[LREG_CALCSUM_J]); */ RCL .01 XEQ 24 STO+ .02
/* increment loop 2 and loop */ DSL .00 JMP calcSumLoop2
/* setPsum((int)LREG[LREG_CALCSUM_J], LREG[LREG_CALCSUM_SUM]); */ RCL .01 RCL .02 XEQ 23
/* loop */ DSL .01 JMP calcSumLoop1
RTN
/* initValues */ LBL 31 LocR 10
/* for (LREG[LREG_INIT_I]=0; LREG[LREG_INIT_I] < (GREG[GREG_DIM]+1); LREG[LREG_INIT_I]++) { */ RCL 00 STO .00 initValuesLoop1:: RCL 00 STO .01 DEC .01 /* for (LREG[LREG_INIT_J] = 0;LREG[LREG_INIT_J] < GREG[GREG_DIM]; LREG[LREG_INIT_J]++) { { */ initValuesLoop2:: RCL .01 /* LREG[LREG_INIT_XOFFSET + (int)LREG[LREG_INIT_J]] = (LREG[LREG_INIT_I] == (LREG[LREG_INIT_J]+1) ? 1.0 : 0.0); */ 0 + RCL .00 0 x[<->] Y x=? Z INC Y DROP
RCL .01 # 114 + x[<->] Y STO[->]Y
/* setP((int)LREG[LREG_INIT_I], (int)LREG[LREG_INIT_J], LREG[LREG_INIT_XOFFSET + (int)LREG[LREG_INIT_J]]); */ RCL .00 RCL .01 [<->] ZXYT XEQ 25
/* increment loop2 and loop */ DSL .01 JMP initValuesLoop2
/* setY((int)LREG[LREG_INIT_I],func(&LREG[LREG_INIT_XOFFSET])); */ RCLS .02
/* increment loop1 and loop */ DSL .00 JMP initValuesLoop1
RTN
Edited: 30 Aug 2013, 5:46 p.m.
