HP Forum Archive 21
[HP-Prime CAS] No pretty print (MathBook)
Message #1 Posted by CompSystems on 22 Aug 2013, 1:59 p.m.
Re: [HP-Prime CAS] No pretty print (MathBook)
Message #2 Posted by Gilles Carpentier on 22 Aug 2013, 2:39 p.m.,
in response to message #1 by CompSystems
imho the red '?' must be on the Nspire for :
desolve(3*x+4*x*y+(2*x+2*y)*y'=0,x,y)
I agree with you about pretty print (by the way why don't use small font on the prime as you do on the TI?). And i'm very confident that this points will be improved in next releases.
As you know, the Prime reserve 'i' and 'e' for imaginary and exp. Perhaps this will change with special i and e chars. Not sure it will be a good idea, there are + and -. in my old math courses I remember that we avoid to use i and e because it's confusing (and in electricity we use j and not i for the same reason). There are no problem in your last example,it's logic.
3i+3i is not very beautifull... Same for e^e
EDIT to your edit ;) A..Z are numericals varaiables. You cant use them in symbolic
Edited: 23 Aug 2013, 5:08 a.m. after one or more responses were posted
Message #3 Posted by CompSystems on 22 Aug 2013, 4:07 p.m.,
in response to message #2 by Gilles Carpentier
* currently e^x in CAS mode, is seen in linear form, e^x in HOME mode ok
* matrix({i,j}) is also observed in linear form =(
* matrix .+ expresion => point has been deleted =(
* matrix .- expresion => point has been deleted =(
* union and intersect, no operator (u/n) has been included =(
* transpose(matrix) => mat^T like mathBook
[request] contact(matrix1, matrix2 ) => matrix1 | matrix2 like mathBook and MAPLE
include smart or pretty printing (didactic) for the solve command,
it requires on programming a new command (expressionTolist) to display the response in list format
