Re: Slowness on WP-34S Message #3 Posted by Marcel Samek on 18 Aug 2013, 2:29 a.m., in response to message #2 by Marcus von Cube, Germany
Marcus,
Actually the SHOW function operates properly. Responds to up/down buttons right away. No apparent slowness.
It is just the STATUS function which is that slow, as far as I can tell. (Approx 2 seconds to respond to each key press)
Computational functions seem normal. 100! returns instantly.
I got to this point in this email and went to run a simple program. I got a strange error (code was approx 2500, I did not write it down). I went into programming mode and was not sure what I was looking at, so I got out of programming mode and did a GTO ..
And.... that seems to have reset everything. Not only was I then able to run the simple program after that, but the STATUS command now operates at fully speed. I had not reset or powered-off the calculator in any way.
M.
