Re: USB Chargers for HP calcs Message #4 Posted by Craig Ruff on 18 Aug 2013, 10:58 p.m., in response to message #2 by Mike T.
USB only provides 5vdc, I don't know enough about the internals of the calculators to know if this would be enough, but I suspect it isn't.
If the total wattage required is not higher than that provided by the USB port, the 5 volts can be raised to a higher voltage with a switching converter, with a proportional reduction in the current. This is the same mechanism a camera flash uses to generate several hundred volts from, perhaps, 6 V of alkaline batteries, or even the internal power supplies of several older HP calculator families.
