HP Prime - transferring between calc and PC Message #1 Posted by Andy B (Australia) on 15 Aug 2013, 12:12 a.m.
With the HP Prime, does anybody know how are apps supposed to be transferred from the PC emulator to the actual calculator?
Arguably one would want to develop serious apps in the emulator and then be able to transfer them to the calc - or to share them with others?
The only thing I can see in the manual is usb cable transfers between calcs. Maybe the pc emulator will talk via USB cable with the calculator? The slightly different cable plug shapes described in the manual worry me a little - is this standards based?
And under Home / Settings are "Wireless Network Properties" though that is probably for configuring the DataStreamer stuff? Would be good if you could directly connect to a wireless network and transfer programs.
P.S. Not sure if there is a better forum for asking these sorts of questions. I found HP's http://h30499.www3.hp.com/t5/Calculators/bd-p/bsc-408#.UgxSemSMGGo though that was by google luck. Certainly trying to find calculators via http://h30434.www3.hp.com/psg/ was difficult/impossible. Then at some stage after registering for the above, and googling some more, I ended up staring at yet another complex HP registration page related to hp passport or something, after which I gave up and came back to the only sensible place I could think of - here!
Edited: 15 Aug 2013, 12:53 a.m.
